Front Shocks
johnjoe64
Lads I think I need a set of front shocks as i get a loud bang when i hit a bump what are best and how much should they cost and how much to fit thanks John L.
Got my rear shocks done in Fast Fit in Coolmine. 190 supplied and fitted. You can get genuine Bilstein shocks from Subaru but I heard they cost 500 each.
dunno how loud it is but if its only when you hit a bump then it could be worn drop links. Happening on my own at the moment. You should have it checked by someone before you go and spend money on new shocks.
stevo said:
@ markobucko - can the top mounts be checked without taking the shock off??
yeah stevo,
just need to jack wheel off the ground!!!!
as robbie said....droplinks would give you a knock on different road surfaces!!!!
:ponder2: :ponder2:
Go for drop links first, definately most common for that clunking noise. cost about 60 euro in c&r and you can change them yourself in about 10 minutes :thumbsup:
Hi john.
With your legacy wishbone bushes are a common premature failure and this may be wat your hearing..
