ali burrows motorsport Octane Boostaholics ISDC Club Member Jun 20, 2011 #1 now block gas ringing and block pinning done inhouse at abm ...
BazGF8 “What’s that noise?” Let it Develop Staff member Jun 20, 2011 #3 Dagnut said: forgive the ignorance but what does the ringing do? Click to expand... x2 , would also be interested to know
OP OP ali burrows motorsport Octane Boostaholics ISDC Club Member Jun 20, 2011 #4 helps make a better compression / combustion seal ..
A Animal spec-c Petrolheads Jun 20, 2011 #5 are the heads machined to match the block?can this be done on all subaru blocks ie 2.0 2.2 and 2.5 ect ????
OP OP ali burrows motorsport Octane Boostaholics ISDC Club Member Jun 20, 2011 #6 just block ... at the minute only doin 2 L .. need a bigger cutting head for milling machine for 2.2 and 2.5 ..
K KENC Well-known member Jun 20, 2011 #7 Ali i suppose its too late to do the gas ringing when a block has allready been assembled or can it be managed? And is there a different head gasket that has to be used or is likes of Cometic still useable? Thanks
OP OP ali burrows motorsport Octane Boostaholics ISDC Club Member Jun 20, 2011 #8 best to do when block is stripped ... still using standard type gasket ..
