They are good i am sure as the have there own coil packs and very hard or near impossible to mix up. Its 1996Are the spark plug leads connected in the right order or what year is the car
Oh ok I must check that out if anc when I get it running again. I also want to change the spark plugs to a much higher quality plug when I get it all sorted.You can mix up the connections easy enough as in mix up front and rear cylinders on both banks
Its 1996What year is the car and what colour is the maf
Ha ha yes to all your answers. I don't mind driving today if your about ?So it’s a green and you’re looking for .
The top of that is modding anyway so someone was messing with it .
would have 1 here but not local to swap in maybe someone closer .
Are you reading the codes from the check engine light blinking .
Long flash is 10
Short flash is 1
