You should upgrade or use an
alternative browser.
Anyone know if a 99 uk impreza 2000 gearbox would fit a legacy B4 2000?
Apologies for all the questions!!!!
The gearbox will fit but you need to ensure that it has the same drop gear ratio, otherwise you'll need to change the rear diff.
Come to think of it, i think the 5 speed used in the early B4's is the same one used in the uk turbo. You'd want to double check that first though
