Very nice looks mint man
Very hard to get a nice clean one most are rotten
There was an rs and a rs-ra what is the difference between them was it just the hand balanced crank and stuff like that and was there a power difference between both
There may be many people who do not know first generation Legacy RS "typeR" & "typeRA" [SIZE=+1]● RS-R
[/SIZE]The Debut of first Legacy WAS the end of January, 1989 (February 1 release). The turbo car WAS only Sedan RS of 5MT at first.
In October, the Same year, RS-R IS Added in Accordance with a Debut of GT Which IS a turbo car of a Wagon (and 4AT version of Sedan RS).
It IS written with "a Basic grade model of RS Which IS Suitable as the Material of a Competition car for Motor Sports" and a new car commentary book.
RS-R, Atype[SIZE=+1]● RS-RA
[/SIZE] In November, '89 (December 1 release), pure Competition car Base for Motor Sports, RS-RA of a STi tune Appear.Therefore the position of RS-R Became Considerably vague Debut Two months later.
It IS written with a new car commentary book with "the order production RA memory model that executed engine fine-tuning same as the challenge car that 100000km speed records RS-R in a base." RA seems to mean, 100000Km speed record Challenge "RECORD ATTEMPT" INSTEAD of RA of Rally.
(There IS an opinion That RA Means "Race groupA") RS-RA put a fine tune to a rally and a dirt trial competition to be based on RS-R more. As for the engine, Forging Piston and high RESIST pressure Connecting Rod metal Are built in, and, as for the Intake port and Exhaust port, it IS revised gap and polished up.
A Crankshaft and the Flywheel Which got of balance Are Mounted the car with.If it is a beginner's class level, suspension is strengthened to the rank who can participate as it is.Variable ratio power steering is important, too.As for this, the steering gear ratio becomes quick. Without Close ratio transmission, it WAS Announced as 100-Limited model at First.Actually, Seem to Have Continued job-order Production of 20 monthly Productions.
Long-awaited Close ratio transmission WAS Carried than a B type from May, '90, and increased with a catalogue model. Engine specifications do not change from a latter period model C type, but ECU becomes 16bit, and a torque up in middle low rev. (Be said by an emission control that became mild) and continued to exist to the last D type, and handed over a duty of RA of legacy to impreza WRX-RA with full model change-over, and the grade of RA disappeared from legacy.
↑ 100 limitation, A-type
↑ close ratio transmission, B-type
↑ After minor Change model C-type ↑ Last model D-type
[SIZE=+1]Engine
[/SIZE]RS-R The engine & Transmissions Are the Same as RS. RS-RA based on RS-R and Handcrafted RA Tuning Same as 100000Km speed record car (RA: RECORD atempt)
crank shaft, flywheel and clutch cover hand finish balance
induction system (cylinder head, intake manifold) hand finish repair gaps and polishing
A gold Alumite treatment surface cam cover
A intake mani-fold decoration cover abolition
An inter air conditioner case special color
A forging piston
forging kelmet high resist pressure connecting rod metal
Turbine rotor Diameters (in / out)
Compressor Impellers Diameters (out / in)
Maximum boost pressure
Intercept point
number of blade
52.5 / 43.0
56.0 / 41.2
450 mmHg
2400 rpm
9
52.5 / 46.5
56.0 / 45.0
2800 rpm
10
[SIZE=+2]■ CHASSIS
[/SIZE]● RS-R
Hardened coil spring, damper and Bush (equal with STi product)
(except Rear differential Mount, TRAILING arm Rear side, a Stabilizer)
Adoption of three spoke steering MOMO "COBRA"
Adoption of an advan "GROVA" high grip tire
The abolition of steering assist power change over switch
● RS-RA
Difference with RS-R
A variable Quick power Steering
gear ratio In going Straight: 15
(over all) In full Steering: 13
The level That CAN just participate in an intermediate class Rally
Hardened Bush (equal with STi product)
(except Rear differential Mount, TRAILING arm Rear side, a Rear Stabilizer)
GT
SEDAN
GT
WAGON
RS
RS-R
RS-RA
Spring rate
(kg / mm)
F
R
2.5-2.8 2.3
2.51
1.89
2.63
2.17
3.2
2.85
Damper damping force
(pull / push 0.3 m / sec)
F
R
126/31
82/25
126/31 82/25
146/97 112/74
190/140 130/85
Stabilizer
(external diameter-mm)
F
R
17?
19?
18
18
17
19
[SIZE=+2]■ Body color[/SIZE]
[SIZE=-1]Apride model →[/SIZE]
A
B
C
D
RS-R
Ceramic white # 57
Dark blue # 56
Ceramic white # 57
Indigo blue-M # 13
Black mica # 52
RS-RA
Ceramic white # 57
Ceramic white # 57
Feather white # 30
Feather white # 30
Black mica # 52
This time, English translation to this place ...[SIZE=+2]
■ body
[/SIZE]● RS-R
differences between the RS simplification of equipment, for weight reduction, abolition or change the following parts
Obsolete parts
power window, centralized door lock, power antenna, rear wiper, rear spoiler (option), the under spoiler, Mafurakatta, tire chains, ignition key lighting, remote control mirror
Change parts
smoked glass → Blue of
colored mirror → blackening
the air conditioning switch (push-type) → lever formalized
floor mat (superlative cut pile) → needle carpet of
roof trim (tricot) → Shiobi-ka
sun visor (mold) → Shiobi-ka
● RS-RA
differences between RS-R
Abolition parts
radio, speaker, trunk mat, undercoat
Handcrafted Tuning by STI mark (front door bottom)
Head lamp strengthen
and change the valve to 60 / 55W → 100 / 80W
Under guard fitted as standard!
Change from the ● B type
Centralized door lock, harness equipment for power Windu (it became to be mounted as an option)
seat fabric, cushion change
(appearance does not change much, but it seems to be improved from the lumbar support none of low back pain sheet)
Plating of the front grille silver paint (RS)
Rear wiper, centralized door lock equipment, front grille body whitening (RS-R)
Cross mission mounted, front grille body-color printing (white frame) (RS-RA)
