help needed............
colmbarr1988
help......... :angry1:ghty temptin to
so started the car to warm it up cleared the windows put the wipers on and only one is movin(driver side)
the other is side is slightly attempt to ,bouth a half inch but no look
now der is no knocking or grinding or strange sounds any ideas??
iv to head for dundalk at 8
could be something has snapped or bent inside the mechanism
I would recommend taking the blades off the window until its defrosted properly as using the wiper blades to clear the ice / frost will just cut the byjapers out of them......
linkage has to be disconnected!!!!
or else the actual wiper arm is loose on the spindle!!!
check the nut on the arm is tight on the splines!!!
:thumbsup: :thumbsup:
tanks lads it is real loose i can move it side to side by hand,
so will try tat
it so poxy cold doe .....
were is tat nut located?
