P planb Sunday Drivers Nov 27, 2010 #1 Hello all, having problem with my front right HID light in my 06 forester, I changed the bulb around and both work, is there a seperate fuse that is not in the usual fuse box ? thanks for any help
F fenster Middle Lane Hogs Nov 28, 2010 #2 If it is an aftermarket kit you will normally find a 20 amp fuse before the ballast unitfor each side. Try swap the ballast unit out
