geogan said:IMO these peak power figures are meaningless for everyday driving. I you are reaching 400BHP that means you are using larger more laggy turbo which only spools up to these peak power figures at stupid RPMs - in the 6000-8000RPM range. Nobody drives normally at over 6000RPM. When you are driving at normal 2-3k RPMs in your 400BHP car you have WAY less than 400BHP available.
My own car has larger turbo which makes up nearly 400Bhp and i have dyno graphs showing power curve - a standard STI turbo reaches its peak power at around 5500RPM and then starts going down again as RPMs get higher. Mine just keeps going up from 5500 all the way to its peak at redline. i.e the extra 140bhp from standard of about 260bhp are in the higher rpm range above 5500 which i 99% never use while driving. And the ironic thing is the other lower end of power graph (because of larger turbo) ends up being LESS bhp than standard so for normal driving i end up with less bhp than a standard STI in the 1000-3000rpm range. I'd be more interested in the torque curve than the bhp curve to gauge overall "fast car" ness...
The only place I actually used the extra power was when I was on track in Mondello because I drove completely "un-normally" and had the RPMs in the 6000-8000RPM range while doing it - of course doing this it used nearly half a tank of E5 for a few laps of track... all the extra mods on car were the only reason it could actually sustain this level of rpm and not blow up engine doing it...
If this is the case, you havent specd your car well. A 400hp car doesnt have to be and shouldnt be laggy.
The how much power is enough question is kind of a pointless one really, if we are to look at things from the point of view that x amount of bhp is too much then we should question why are we driving performance cars when the speed limit is 60MPH... Like my ould lad always says.
