If u didnt have a Scooby
this is it dagnut ,im only picking it up this weekend in england
they want 4 grand paul the bastards but im looking into it
very hard to say.....   is this a money no object question or an old skool thread.....
old skool E34 M5    And i was lucky enough to have owned this one last year....
So been there done that..
Second choice be a Audi RS2. But would have to be a RHD...  Still making 11k sterling
FROM FACTORY :shock:
Performance figures
Power 315 bhp / 235 KW @ 6500 rpm
Torque 410 Nm / 302 ft lbs @ 3000 rpm
BHP/Liter 142 bhp / liter
Power to weight ratio 0.2 bhp / kg
Top Speed 265 km/h / 165 mph
0-60 mph Acceleration 4.8 s
General specifications
Record last updated  Before 12 / 01 / 2004
Country of origin  Germany
Numbers built  2891
Years of production  1993 - 1995
Engine
Engine  Straight 5
Engine Location  Front , longitudinally mounted
Configuration  cast-iron block, aluminum alloy head
Displacement  2.226 liter / 135.8 cu in
Bore / Stroke  81.0 mm (3.2 in) / 86.4 mm (3.4 in)
Valvetrain  4 valves / cylinder, DOHC
Fuel feed  Bosch Fuel injection
Aspiration  Garrett K28 Turbo
Drivetrain
Chassis/body  unitary steel
Front suspension  multilink, lower wishbones, coil springs, anti-roll bar
Rear suspension  Double wishbones, anti-roll bar
Steering  rack-and-pinion, power assisted
Brakes  Porsche vented discs, all-round
Gearbox  6 speed Manual
Drive  Quattro All wheel drive
Dimensions
Weight  1595 kilo / 3516.4 lbs
Length / Width / Height  4496 mm (177 in) / 1702 mm (67 in) / 1397 mm (55 in)
Wheelbase / Track (fr/r)  2591 mm (102 in) / N/A / N/A
Performance figures
Duffman that Integrale is sweeeeeeet - I'm very jealous.
The car I would most like to own (within a reasonable budget) would be Mk1 Escort
If budget wasn't such an issue then 1973 Porsche 911 RS 2.7
Can someone please teach me how to post pic's :computer: :computer: :computer: :computer: fooking p*xy thing
One of these:
With a bit of this inside..
[quote author=davelegacy link=topic=4975.msg54681#msg54681 date=1200428104]
..a Audi RS2...
Performance figures
General specifications
Engine
Engine Straight 5
Engine Location Front , longitudinally mounted
Configuration cast-iron block, aluminum alloy head
Displacement 2.226 liter / 135.8 cu in
Bore / Stroke 81.0 mm (3.2 in) / 86.4 mm (3.4 in)
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Bosch Fuel injection
Aspiration Garrett K28 Turbo
Drivetrain
Chassis/body unitary steel
Front suspension multilink, lower wishbones, coil springs, anti-roll bar
Rear suspension Double wishbones, anti-roll bar
Steering rack-and-pinion, power assisted
Brakes Porsche vented discs, all-round
Gearbox 6 speed Manual
Drive Quattro All wheel drive
Performance figures
Power 315 bhp / 235 KW @ 6500 rpm
Torque 410 Nm / 302 ft lbs @ 3000 rpm
Power to weight ratio 0.2 bhp / kg
Top Speed 265 km/h / 165 mph
0-60 mph Acceleration 4.8 s
But replace the K28 with a GT30
add a tubular manifold, reverse the inlet manifold and remap for 500 instead of 315bhp..
Everyone is going for old classics. If ye had to drive these everyday i think some of ye might change yere minds. Heaters taking hours to heat up. Not starting on cold mornings, no power steering  :noway:
[quote author=kanye from the west link=topic=4975.msg54792#msg54792 date=1200439818]
yeah i agree the OP said realistically
Id have to say E46 M3 too, possibly couldnt strectch to CSL money but a non CSL model is not what you would call slow!!
