Inner arch liner
I bought two new ones after the last trackday..... I did..
Nearly sure you were onboard when the car chewed them off...!!
Anyway... get them new genuine from Subaru... around 90 each.
If you like a polished/detailed machine.... new ones look great when fitted.
You?d nearly laquer them when fitted to keep the new look!
I didn?t.. real dirty now!
Best bet really, if you were to buy second hand you can?t
Really tell by looking if it?s in proper shape/condition!
You will only really know when fitting if it works.
Noel will know the score and get the correct one for you.
Check out the massive cardboard box they come in!!!
Your green bin will be full :)
Got two before and was some crack cramming them into the impreza.... :)
I'm on my second set of used and if all mounting points are intact there should be no problem. See seanie was braking a blob sti he may have them if not damaged in the accident. They go for nothing used
