little help
J
johnroake
Guest
this is nothing major, but i have a 1996 jap wrx, u know the button u push for the water for the windscreen wiper, there is water in the tank but it is not squirting, could u tell me if it is just a fuse or something loose or wat.
Can you hear the motor when you push the button or is anything happening at all? Motor could be burned out or clogged up with crap!? Have you checked to see if there are any blown fuses?
there is no noise at all, didnt even think it could be motor. wat can i do with that
Well firstly check all the fuses make sure none are blown before you get into motor replacement. Check the connections too...wires going to the Washer Bottle. The pic is off my Legacy (front of the bottle) but they are usually the same...
