Logging without the Laptop
Prinz
Just bought a 2Gb micro SD card to put into my OBDII connector.
Have to do a ROM update and then apparently I can do some logging to the card without having to have the laptop on board.
By the sounds of it I have to supply the config I'm interested in and then once were driving I can either manually trigger the logging using the rear demister or it can be automatically schedueled between 2000 and 7000 rpm.
All I need now is the time to be able to get the kit ready and hey presto :thumbsup:
Cheers, P.
All the updates applied successfully and having inserted the memory card I took her out for a spin.
I had edited the config file to allow for start/stop using the demister - but you can use rpm's, the clutch switch, the A/C switch etc.
Did 3 runs and it logged OK but my sampling rate was too slow so I only didn't get enough data.
Probably try again on Paddy's day when I have more time.
Cheers, P.
