looking for a few bits
JGARDE
Middle Lane Hogs
alrights lads i went through the car with a mechanic the other day i am looking for a few bits money it a bit tight at the mo anything considered cheers
1) rear shock top mounts left and right
2) cat back exhaust cause old one is damaged flange broken and a hole in backbox
3) front wishbone bushes the back bush left and right
4) rear drive shaft left one it was rubbing the exhaust and melted the grease in the join and the cv joint wore away without grease
the car is a 00 wrx newage
are any of the classic parts the same as above
thanks lads
if the exhaust aint too bad ill patch it for u lad im down in kerry, ud be amazed at some of the scrap the local farmers have brought me
i dont think its worth repairing lad the drive shat wore a hole into it cause the exhaust got caught and bent up against the shaft a wore away
can you send a pic of it i say they be nearly the same as newage cant be much different unless anyone can say different!!?? :thumbsup: :smile:
I've got a full PPP exhaust taken of MY03 Sti, it's got a bit of surface rust but backbox is ok.
Where are you based mate?
I'm in Dublin but will be in Kerry (near Glenbeigh) all weekend (driving down tonight) - not too far from Cork.
markobucko said:
newage and classic exhaust systems are different!!!
:thumbsup:
hes car is probably similiar to mine which is the same as the classic as they are the first of the newage so it would be best to check it out before you buy anything
my bad !!! sorry!!!
when i was buying my own exhaust system,the seller needed to know was it newage or classic!!!
:dontknow: :dontknow:
