Loose Window Glass.
johnjoe64
Hi Folks the glass on my passenger door is very loose like if I push it theres a lot of travel in it is there a way to tighten it up to stop it flexing so much many thanks John L.
Not sure what you're driving John, but the classics had a tendency to have the window winding mechanism work itself a bit loose. Have never done it myself but have seen it been tightened up. Take off the door card and plastic undereath and tighten up any bolts you see. Might do the trick!
