Mapping in September
1. scoobycolm. my00 type uk turbo ecutek tweak
2. Forester Sti (Dan) '06 Forester Sti ecutek tweak I'll remove my name from Scooby Ireland list!
3. Nic Spec C - Simtek tweak
4.coopster my05 forester ecutek tweak - date depending if its the weekend 11th or 12th sept thats a go thumb
5.Rudeboy - simtek tweak
6.marek-irl - simtek tweak , If I'll return from vacation
7.
8.
jackswagon said:
Im in the usa till the 9th sept simon.
can you confirm what days your going ahead with this down south pls. :thumbsup:
Have to bear with me slightly as I am on holiday at the mo.
I suspect 9th and 10th, until I have checked ferry times and know numbers it is hard to be sure.
7. keith555 - v3 uk turbo - simtek tweak - date depending
8.
Would anyone be able give me a rough guide on price for the required re-map after a turbo up grade. From a Vf30 standard to a TD05 18G.
Dont wanna stick my name on the list if it'll be more than I can afford.
Thanks in advance! :thumbsup:
If mapped with ecutek already £352.50GBP otherwise £646.62GBP.
Sorry to quote in pounds but no upto speed on exchange rate and my mobile card machine only works in pounds.
352.00 GBP = 423.079 EUR
will be slightly different on the day due to changing exchange rate :thumbsup:
on your website Simon it says "subsequent remaps from 150 pounds "
does this mean that if i come back to you after i get my car mapped by you it will then be cheaper the next time :dontknow:
many thanks colm
That's the idea colm,
Plus a share of the travel and accomidation costs!
Dan
many thanks colm
Yes :)
8.larsti8- v4 type r, full simtek .antilag and launch setup
9. Jackswagon, v6 classic. Simtek tweak. Date depending on if its 11th or 12th sep as away untill then.
10. hiwd, V4 classic. Apexi Power FC map
Any update on date Simon. I am away from 5th to the 12th so can meet up north with you if between them dates. :thumbsup:
I am travelling most likely on the 6th and be up north 7th and part oth 8th and south 8th and 9th maybe 10th too
Still away at the moment so not had time to plan and look at ferry times etc yet
Simon
Keith,
I am very sure some one would look after your car for you if you like!
I could get mine mapped, leave my car at yours and go mapping with your car, then leave her home,
If you are stuck!
Dan
No problem Simon. :thumbsup:
Cheers Dan. :thumbsup: :thumbsup:
If you could do that for me that would be great :thumbsup: as I was going to see if DUFFMAN could do it but he is away at the same time.
No bother Man!
Sure it'll be a bit of craic!
We can finalise details at the BBQ/Charity event! :thumbsup:
Dan
