Wheel bearing would be more of a hum tho, this is literally a grinding like, metal grinding. Wierd, I thought it may have been a driveshaft loose or something when I heard it first, actually no, I thought pads, but it's not.
No vibration through the steering or anything either. It's on rotation, so as the wheel turns it will grind, then stop then grind etc etc
Speeds up as you go faster then. Does sound like brakes, but he had the wheel off and inspected pads and all that too
have a bearing got just in case.
If it?s bad enough it will grind and if a drive shaft nut was loose the bearing it definitely gone lol, also they don?t usually give any indication they are gone as in vibration etc .
Speaking from a lot of experience unfortunately [emoji23]
Stone between the dust shield and disk or disk rubbing the dust shield
