my pu-ka project
For sure its a great job to have retro fitted two cages into a KA,padden will hide the kink but I dont think they will bother ya too much,one of the scrutinisers down there is sound the other is a bit funny we will go to the sound lad[emoji106]
I changed the seats because the head hugger part was sticking out to far and the door bars are so high I couldn't get out of the thing
wouldn't fancy trying to get out in a hurry still with the new seats and the old seats were for a greyhound
[emoji1][emoji1]
And your car is the reason I kept the door bars low in mine Keith the day I drove yours I kept banging my elbow on the bar lol
Seat needed to go back we only fit them that morning in mondello so brackets need to go back then your elbow would be straight and it then will clear the door bars
Ah right I was wondering that alright you should do japfest time attack too keith be good craic
wagon dec
All the dash, heating system and unwanted wiring now removed collecting the corsa steering column tomorrow night and Hope to fit Saturday
http://images.tapatalk-cdn.com
Also removed the cage to send for paint all this thanks to my mate who does shift work and was off happy days ????
wagon dec
Good bit done today removed all the ford steering column and fitted the corsa electric unit also panelled off the whole left where the heater box used to be happy with the results
wagon dec
also started some quick drawing of the top mount im going to make to adjust the caster ,and then fit these top mounts to those plates to adjust camber that should allow me to run less camber and more caster ,which will give me more dynamic camber in the turns and with the other mods hopefully under 2.05 if it fails ill add more power
looks good, did you have much of a job with splines? or did you cut and join the shaft? nice little blank for the heater box, so many people do ugly jobs when its not on show.
i think you may go all out at this stage and give the inside a lick of paint before the cage goes back in.
