So off to a private road local to us for a bit of testing and it went very well only two issues with it.
One was the idle screw came loose and jammed the throttle closed so big thanks to @dunnervts for his help and tools to fix it on the spot.
Next issue is that the alternator is overcharging alot we were seeing nearly 20 volts on the meter so we disconnected the alternator and it was grand. Need to get the alternator checked and solve the problem but overall I'm very happy with its first drive in 9 months. Some work still to do but we are close [emoji16][emoji108]
Sent from my F8331 using Tapatalk
