Guys,
My 99 GC8 has failed its latest NCT, bad corrosion on both sills, just front of the rear wheels. At these locations the outriggers from the rear diff support connect to brackets that connect to the sills. This complicates things and makes the job more difficult. I previously had sill issues around the front jack points, these were repaired by AJK in Lusk but they will not touch this. Can you or any of the lads on the forum give me a recommendation on who is capable of repairing this corrosion, I'd appreciate it. The car has 176k on it and the engine is running like a clock so there are still a lot of good things to be said about the car. I have owned it from new so I'd be sad to see it condemned.
PS:
In the attached rear diff outrigger illustrated parts breakdown, the part labelled ?41331A? is the bracket that attaches to the sill locations rotted out on my car. The bolt identified as ?5? in the drawing secures the outrigger to the car body through the bushing identified as ?41326?. This thankfully is in good condition therefore the outrigger is secure.
Thanks and Regards
Ciaran
087 9675 086
PS:
Thanks and Regards
Ciaran
087 9675 086
