Just back from NCT, failed on high idle CO levels, limit is 0.20% my reading was 1.59%
Exhaust is Milltek with sports cat, I also put standard airbox with K&N panel back on.
All other readings within acceptable values...
Low idle
(759 rpm)
CO 0.12% Limit 0.30%
HC 24 ppm
High idle
(2887 rpm)
Lambda 1.00 Limit 0.97 to 1.03
CO 1.59% Limit 0.20%
HC 81 ppm Limit 200 ppm
Any ideas on how I can get the CO levels down?
Cheers,
Steve
Low idle
(759 rpm)
HC 24 ppm
High idle
(2887 rpm)
Cheers,
Steve
