NCT parts
Jarocki
Michael
Hey all. Failed the NCT on a few suspension parts hoping for some advice. Car is 2006 BP5 legacy estate.
Failed on both front anti roll bar bushes and links. Can these be changed and sourced separately?
Failed on both front wishbone WB bushes says rearmost on sheet. Can these also be changed without having to replace to whole wishbone on each side?
Thanks for all the advice.
Won?t comment on wishbones as I?m not certain. ARB bushes and links can all be easily sourced and bought separately. Is it the standard ARB on the car or is it upgraded/thicker - if so, this will affect the bushes you need. Endlinks should be standard regardless of the ARB size - plenty of upgrade options available.
Check the likes of whiteline for upgrade options or ICP for oem stuff.
Thanks for that. I didn't upgrade the ARB. So i would imagine it's standard since it was imported. I will have a look and see what parts i can source for them. Thanks
The rear control arm bushes can be got separate aswell , just order from Subaru with your chassis number , probably cheaper to get them here rather than paying shipping from the uk for something that size they wouldn?t be that dear . The links would be expensive for genuine but they last a lot longer than spurious.
Got the drop links replaced and bushes on the arms replaced and passed the NCT there on Saturday. Thanks for all the advise.
