nct tomorrow morn.
duffmancb
lads i have the nct tomorrow morning and there is a Clifford alarm on the car and needs a code to be started i heard you can put them into valet mode and that will let them drive it. i also had a look at the manual online and doesn't say much about what valet mode does only how to get it into it and out of it so does anybody know what exactly happens when its in valet mode? bit worried they will not take the car if they cant start it to bring it in :dontknow:
write the code on a post-it and just leave it on the seat, i doubt he'll steal it,
and if your paranoid can you then change it after?
yeah that's a good idea ill do that i don't mind him knowing the code, i was thinking if they couldn't start it or get confused with it that they will just fail it for nct. :thumbsup:
I think this is what your after..
Bypass it as above, do not give out your code to anyone. You never know who you're dealing with and they have access to your address.
yeah it just went through there and i started it for them.
i must have the record for most failed stuff on the nct for a scoob :angry1:
Doubt it bet mine was longer and I got a big failed dangerous do not drive sticker on the window
haha got any pics of that sticker sounds gas :lolpoint:
its a 98 type r
heres what mine failed on
side/slip alignment test-
ftont axle 4.6m/km fail
rear axle -2.0m/km fail
exhaust emissions-
high idle lambda 1.40 has to be between 0.97 and 1.03 fail
visual/aural defects -
tyre specs protrude behind body offside front fail
tyre specs protrude behind body nearside front fail
tyre specs protrude behind body offside rear fail
tyre specs protrude behind body nearside rear fail
exhaust system noise above 99db fail (was at 104db) out of everything this pissed me off the most because it has original catted down-pipe and a zero sports exhaust thats meant to be quieter than stock doesnt help that he revved the arse out of it 4 or 5 times.
steering rack gaitor is not in fail
repeat side slip test? (dont know what that is) fail
brake lines on all four corners were insecure fail ( changed to coilovers a few months back and havent got them rubber things that mount to coils)
bodywork secondary structure condition fail (theres a hole in the passenger arch that needs a bit of welding).
i knew it would fail on the hole and wheel setup but didnt think it was this bad
EDIT: i dont think it failed on the alignment test but it does have N/D highlighted beside it
F****k, a bit of sortin out to be done :wall: :doh:. mine is due in a few weeks. Does anyone know if that bypass works on the jap sigma alarm.
Don't have pic I see can I get one I stuck it iup on mates garage
Plastic version of one you get for parking stuck right in drivers line of sight your man told me drive it of I want but if he sees me he has to ring the law
Waited till he went back in an out there I got
It was for tiny crack on brake disc said could explode anytime
Failled on
Emmisions
Noise
1 tyre
Lights off focus
Pedal rubbers missing
Front plate insecure/missing was in the boot
Washers not working - only ran out didn't notice
Airbag light missing - some fuk had tinfoil over it dont know why it was working perfect
Side slip failed
No,doubt it thats for the Clifford black jax anti hijack
dint know there was such a thing :roll:
I know two other lads got them
One with almera tiny brake fluid leak from back caliper he was happy enough he didn't know was there could have been dodgy
Other lad with e30 325 filled it with petrol and it started leaking in there they pushed it out the door and couldn't let other cars in till some crowd came and cleaned up the spill
Mine wasn't to bad compared to them :multijump:
