Right lads, I've new gauges in the car with a few months. Everything works, but oil temp gauge isn't getting a reading from the oil.
The gauge is working, the sensor is working, as the gauge will read ambient engine bay temp when the car is idling parked up. So temp will hit 50 or 60 degrees when it's parked for 10 mins or so, but as soon as you start driving, the air flow cools the little block the sensor is in and it drops down to the bottom of the gauge again.
Its plumbed in, with the pressure sensor, under the intercooler.
Is the temp gauge better to be plumbed with a sandwich plate at the oil filter?
I think it's just not getting oil flow through the hose to the sensor
