Embrace you’re inner nerdJEAZUS CHRIST
I'm getting another headache![]()
BrilliantI think I found the problem
I might try that, we did take out the sensor itself after a spin and it was bone dry, but deffo worth checking if it's getting any oil to begin withSorry for all the messing ,
I think there could be a blockage somewhere not allowing oil up to that sensor ,
A way to check would be to unplug the crack sensor , remove the temp sensor and get someone to crank the engine (it won’t start) and see if oil comes out,
Put a few rags down
I used a sandwich plate in the WRX that time.. But was kind of advised against it then as it makes the oil filter sit about an inch lower and if it caught anything and ripped off or something your fucked..ones Iv used before had a way shorter pipe and plumbed in under the alternator and sat just in front of the inlet .
So would have being getting cold air aswell but there was no issue With it.
A sandwich plate is a better job with both sensors in it on the top of the oil filter that’s a defi 1 below and Iv never had any issue with apart from a sensor going bad but that’s normal
Why did you message them if you didn't buy them off them or am I missing something?Haha I know
I my defence, it didn't come with a Subaru specific manual
I didn't buy them from Scoobyworld as they only have 52mm gauges, sorted anyway, will tackle it another day and report back![]()
