Pipe conecting intercooler to dumpvalve
collieno
I am looking for the pipe that connects the dump valve to the intercooler on the STI's. The WRX are fixed conections where as STI's bolt off at the intercooler, anyone have one?
I am looking for the bit that bolts on to the flange in this picture or do the dumpvalves fit straight on here on the sti's?
:ponder2: :ponder2:
the intercooler has the dumpvalve bolted to it...ie(no pipes) AFAIK
is that the small vacuum pipe or the larger pipe that goes to the inlet pipe????
any pics lad!!!
sorry,you posted a pic while i was typing a reply!!!
:icon_grin: :icon_grin:
My intercooler looks like that one above, note the black bit coming out. Does the STI intercooler i got just require a flange and then the dumpvalve bolts on there? Sorry it kinda hard to explain what i am talking about
The Dump valve just bolts on there unlike the earlier ones which have a flange welded into the intercoooler and had a hose coming off
it and going to the DV
Thanks, so i just need to get a flange to get my DV to fit that set up?
i have a standard sti newage dumpvalve in the house her if u need one!!!!
bolt to intercooler and connect the larger pipe to the underneath of the valve...
then the small vacuum pipe to the top of the valve...
:thumbsup: :thumbsup:
are you fitting an sti intercooler to a wrx model???
He may not be able to fit it Marko as the pipe that fits to the bottom of your DV is located in a differant place on the earlier models
i have a forge dump valve that bolts straight onto that intercooler, give me a bell if interested 0861920921
Thanks for the offer but as 555-scooby said. The one i have is off a V5 so the one in the pic is the newer type so i dont think the one you have would fit. Ye mine is a WRX type-r and i have an STI intercooler that i want to put in
