Rear window water jet not workin
Check in your boot that the little hose hasn't come out, could have caught in something you were putting into or removing from boot.
Could also be clogged up so if the above doesn't work try getting a pin & cleaning out the spray nossles.
Can you hear the motor working? If you can then its as Brian said, if not then either the motors fooked or theres a break in the connection. Does the rear wiper work even though no water is coming out?
Happened to mine a few weeks ago...turned out the hose was kinked where it attached to the bottle under the bonnet.
so just had a quick mess with it there water is getting from water bottle to boot, there is a join there where i disconnected it to check and got a face full of screen wash. problem seems to be in the last bit of hosing or nozzle, cleared the nozzle and stil no joy so must be a block in the little bit of piping that disappears under the rear parcel shelf. Will try clear it out with some air hose maybe
Best of luck with in!
At least it wasn't leaking somewhere, You'd have a spare wheel well full of windscreen wash! :lol:
Your spare wheel would be nice and clean! Although, knowing you, it probably already is!
@ collieno, is the washer motor handy to get at??
on mine its down below the washer bottle in the engine bay, can probably be accessed from behind the wheel arch lining
Ye mine seems easy enough to get at alright, down below washer bottle. Or even do the actuators give trouble on them? sorry for hijacking thread
I know the headlight washer pump is 100 + euro cause i bought a new from c&r a few months back. Hate it when little things like that dont work. I'd say the screen washer pump is less as its not as high a pressure jobbie AFAIK........... :thumbsup:
