Zheiko
Info about my car: MY07 2.0RX Hawkeye Sedan
So, this is quite big topic, and I have heard plenty of ppl are having issues with this. Frankly, up until I started getting the damn errors, I have never heard of it.
So here is list of errors my OBD reader returns:
P2433 - Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Bank 1
P2444 - Secondary Air Injection System Pump Stuck ON
P1410 - Secondary Air Injection System Switching Valve Stuck Open
these are the most common ones and I got also one, that doesnt seem to be related to the whole thing:
p0510 - Closed Throttle Position Switch Malfunction
Now, there might be several solutions to these problems, that some of you might have tried and worked?
Two solutions I have been told would be, complete removal as its useless, but that would need programable ECU where the faults can be removed. Not sure how that applies to my 2.0R, if I can get different ECU and whether it can get mapped for my car? This would be possibly cheaper solution, as ECU costs about 200-250yoyos and same pricerange goes for Mapping, so total would be about 5-600 yoyos.
Second solution is more expensive, 1500yoyos, and would mean whole system replacement, pump and both valves, possibly even the lead hoses.
Any advices are welcome. I was thinking about disassembling and full cleaning of the system? Could that work?
