Rob Spec C
Altezza-Dan said:2 cans should sort you. pity its not available anywhere in ireland, if it is i couldnt find it! Make sure you build it up in light layers and leave it dry for at least an hour between each coat. 4-5 coats to build it up to a thick layer that can easily be pulled off is best.
Cleancar are stocking it now. Was hoping i could get away with 1 can but I suppose I can get 2 just in case and I'll make use of it anyway
