Squeaking coming from car
poc82
i was involved in a bit of a shunt when we had the black ice on the roads acouple of weeks back which resulted in a broken wishbone and a bent tie rod got all that repaired and the wheels aligned it happened to the passenger side, now there is a squeaking noise coming from what sounds like the drivers side does anybody have any idea what this might be.
Cheers
might sound like a stupid question but what kind of squeak is it?
ie. Prolonged squeal or mouse like short squeak
also does it happen when ya put pressure on suspension or when ya drive forward and back?
it is a prolonged squeak happens when i'm driving i don't think it happens when you put pressure on the suspension.
sounds like the hub to me, my girlfriends car is doin the same, if the wheel got a good hit its likely it could have caused stress on the bearing, :thumbsup:
that would suggest to me its not the likes of a bushion gone!
have you checked breaks or anything like that?
When was the last service? Everything got grease on it that should have?
Don't thinks it's the brakes altho they do need to be greased they are squeaking under braking but the pads still have plenty of life on them, i'll get it to mechanic to have a look
thanks for the help :thumbsup:
