I have a bad squicking coming from the front wheels. I think it mite be my front dics.Mite need new one's
It is very bad when I turn right or left.did any one ever have the same prob.I drive a 2005 sti if that is any help
[quote author=scoobyjoe link=topic=24451.msg290095#msg290095 date=1277021582]
dont think its the wheel bearing.....it wouldnt get worse from turning and it wouldnt be a squeeking noise.......more a whining noise
could be one of the belts slipping....
iv had two bearings that only squeeked wen the steering wheel was turned..it didnt squeek wen running in a straight line so dont eliminate it yet...jack her up and see is their any play in the wheels by rocking them then you can eliminate the bearing
I had something similar a few years ago. Check your wheel nuts, just in case one has worked it's way loose. The other thing I would check is for a cracked alloy. You never know it could be something as simple as that.
