sti discs with 4 pot wrx calipers ??
wagon dec
Member Number 257
well lads just wondering as im sure we have some good engineering types on here somewhere ,has any of you ever tried to fit sti discs on a wrx by making godspeed type adaptor brackets and using the wrx 4 pots .just thinking out loud as I have some discs in the shed and was goin to try it
aston martin db7 pads fit the wrx caliper but are about 10-15mm deeper so pads woodnt be an issue
Would brembos be less work :dontknow:are the discs the same thickness . I think Godspeed put a spacer between the 2 halfs to make there big kit work
oh ye definitely joe just thinking out load as I have the parts and can do the engineering myself ,but I hadn't taught of the spacer in the caliper fair play joe
I got the kit off scally but the disks were fooked
And far to expensive to replace, I could buy brembo's with discs and pads cheaper so I didn't keep them.
I gave them to a lad of here that took some parts off me.
Can't remember who but I'll find out and see has he used them
