I dont know user "randon rs" so forgive me.
The V2 STi is NOT better then V3 STi engine.
A short engine cannot create power by itself. Only internal components and strength reliability which all at the era and age where never designed past factory output at 260-280. Normally in modified terms call it a day early to mid 300's. Both run same compression ratio.
Power is made through head design. Cam profile and breathing abilities.
So weather WRX or STi the short engine is irrelivent. As neither can produce anymore horse power on its own.
Of course cam profile and valve opening duration can. But not by too much until you go up in hp. As in 15bhp at 300bhp for example. And similer torque increase. The V3/V4 STi head produce a lot better results hands down.
A vf23/24 V3/4 WRX/STi turbo will produce similar to TD05 16g. If not a more little more cleaner.
