Has anyone had a similar issue to this.
On my V6 turbo 2000 when the car is stone cold it seems to hesitate slightly but nothing major it quickly goes away and when in low gears at between 1500-2000rpm if your barely on the throttle crawling in slow traffic it will buck notably give it more throttle or at higher revs no issues.
All goes away when Upto temp.
Recently changed the airflow sensor,temp gauge reads at correct level so assuming it's not that and assuming if O2 sensor wouldn't run right when Upto heat.
