keith dublin
Asd doing belt change new coolant and new thermostat for 500 yoyos
400 all in and you supplied the parts you bought
And those 400 yoyos is with all the pulleys and stuff?
That said driver side of engine was dry, it's only on passenger side. I'd or five to change seal only on one side, I guess so.Sound like rocker seals weeping common issue on subarus not a massive job wagon dec here did mine last year..
Keep a eye on oil level [emoji106]
It?s not a difficult job if you take your time and fork out ?20 for a cam locking tool.
Yea only one side normally weeps (cant remember which) but be good practice to get both done when going to effort imoThat said driver side of engine was dry, it's only on passenger side. I'd or five to change seal only on one side, I guess so.
What work be a reasonable quote from garage for part and job? My budget is tight this month after doing timing belt and water pump.
My advice would be to confirm exactly where leak is coming from. As currently its only a guess.That said driver side of engine was dry, it's only on passenger side. I'd or five to change seal only on one side, I guess so.
