Track day car
Thanks Joe mirrors may not be very useful as mirrors go but they are lighter that the big yoaks that were on there.
When are you planning on getting on track? Would love to see it going now. Its going to be a different car totally....
No idea really Martin,just need time to get all the bits back together.But I do hope around mid February to at least have it running again.It should be a very different car Martin as we done a little work in almost every area.
Power,gearbox,suspension,
Weight,rewire,ecu,hopefully it will be better as I want it to chase a few Itcc Hondas[emoji6]
Pembrey would be nice experience [emoji106]
Not been a lot going on lately as haven't had a lot of time.But have been tipping away with the wiring and at last it's nearly sorted.Cant believe the amount that's involved!
But I'm happy it's starting too look like a car inside again.
Lots of tidying to do but it's getting there.
Got back into the garage tonight for a few hours. I got my new light weight race mirrors sorted and also got pretty much the last of the wiring done. Still working on the gearbox but hopefully I will have that sorted soon as then this job can really pick up the pace.
Huge difference in weight and size.
New race battery and bracket sorted today.
I'll feel a lot safer with this on the floor rather than the big box of acid.
Things have been quite for a while as I have had very little time and money to get this job moved on. This weekend things did start to move forward. First up was getting some nice uprated engine and gearbox mounts to help firm things up. Then I finally got the lsd fitted and gearbox back together. So between last night and a few hours today the gearbox has been fitted and one side of the new front suspension is done. It's getting down to the small nitty little bits now so near time to start making lists.
I'll have to do a clean up on the discs or just replace them. I have a set of RC6 pads got so to make the best of them these discs will need work.
Probably should have sprayed or cleaned up the suspension but I'm kinda getting tight on time and need to get testing,I'll do a job on these some other time.
Fair play Adrian, real dedication.
RC6 pads are fantastic, I used them on the megane RS and I couldn't fault them 1 bit.
Cheers man I used RC5+ last year so I'm looking forward to seeing how the Rc 6 compare[emoji106]
