Tryin to find a Intake System
I
iceman666
Guest
maybe someone can help me..
Im tryin to find an intake system for my 05 imperza 1.6 ts... i have a picture of one, but i have looked everywhere online and can not find anything that looks even close to it.
Maybe someone knows where i can get one or maybe has one for sale.
http://yfrog.com/6e26102007196j
That looks customised!!
Maybe you need to look in yoy a metal fabricators??
If your throttle body is 70mm (like the sti) then get an fabricator to bend some 70mm tubing to your own liking, then stick a cone on the end!
Best of luck, I hope someone can be more help to you!
Better off with the factory airbox and a good panel filter from Green or K&N. No point in an intake system like that on a 1.6.
when i bought the car, the side air box that was attached to the wing was gone, and he just stuck a sports fliter on... the Main Air box is still there just no filter in it. its really messy.
Hense why i just wanted to just take it all out put the pipe instead.. where would i be able to get the replacement side air box that conencts to the wing and i could then get the right panel filter in for the main box...
Better off puttins back to standard.Had a intake system on 1.6 and eventually caused more problems than worth it.
Search the traders section someone there should be able to sort you out.
:smokin:
:smokin:
great i just did it... hopefully someone can help me get this back to the way it should be :)
