uncle Z
itsuncleZ
hi there guys I would love to introduce myself, I just decided to join the forum only now but i have owned a wrx for almost a 9 months. i have had problems finding a good mechanic, I have met dave three times and i understand that he is a busy gentleman, however my current problem is that i suspect a small leak when the car is a bit hot after a run/or when the weather is a bit warm (around 23-5 degrees c) i would like to know if any of you would be able to help me find a good mechanic in dublin asides from dave.
kindest regards
uncle Z
I see that's robbies from cork old hawk wrx with some nice mods done to it, I had a few laps in it at mondello, lovely. Car. best of luck with it.
its an exhaust leak but im not sure where i can hear it well when i drive next or close to a wall
thank you all for the warm welcoming and i realpy appreciate your help
kindest regards
uncle Z
davelegacy[emoji769 said:
;539671]Are you on 3 cylinders as when seen last?
no actually i managed to fix it, the 4th cylinder was not working from a wire when we opened up the plastic coating on the wire we were stunned as the copper wiring was very thick at both ends but gradually decreased in thickness as it approached the middle part of the wire where it had only one very thin thread of copper given the fact there were no signs of burns on any part of the plastic coating or the copper wiring in the wire!!
