How is it blocking the rad?
How much do you think it's going to cost you to get a custom intercooler and radiator made up? Then you will need to buy fans that will work, you may cut your bonnet open, possibly cut your front panel... and all the fabrication needed... it's going to be crazy money, and the car will be cut up.. if it was me and pipework being short was a big concern, either the bolt in Lateral performance solution or an RS500 ic... but when it's all done chances are you will see ZERO difference in performance over the everyday run of the mill Front mount set up.
