chris139ryan
I done a 06 530d and the engine mount bolts on rh side were sheared, it soundedlike the sub frame was loose
Was the car showing similar symptoms to what mine is ? I hope its a little fix like that
how low of speed are you getting it? i presume its an e60, they give plenty of problems that would have similar symtoms. is it a vibration through the wheel rather than a wobble?
Had the car up again last Saturday on a ramp checked all bushings front and back, steering column, discs, wheels, balancing. There's nothing loose under the car.
I have it booked it with the specialist I bring it to get serviced on Wednesday. Will let you know what he says.
Only other things I can think of would be mounts/bearing but I'm far from an expert when it comes to cars
Spacers will be changed first when up with them id say. Quality of spacers were never mentioned to me when fitting them and I had no previous experience with them
I thought the wheels were rubbing without the spacers ?
If not I'd do what baz said
