water pump
if the impeller broke ,the car would overheat from lack of circulation of water!!!
if the bearing collapsed , the pump would be roaring same as a wheel bearing!!!
other than that it would have to be leaking!!!1
:thumbsup: :thumbsup:
dont just assume its a water pump coz you have a water leak....
frost plugs or hoses!!!!!
where is the leak coming from????
:ponder2: :ponder2:
usually when the pump leaks you will see it running from the t belt cover close to where the bottom rad hose meets the engine. so you've been through water leak, head, head gasket and now water pump. i think it's more cycalogical if you ask me :cuckoo:
how could it possibly be psychological if the car is overheating. Obviously somethin wrong and he needs it sorted, not a smart reply like that
chill out man, was havin a laugh with him. if you look at his other posts on this same overheating, he's a sound bloke well up for a laugh. nice to see someone looking out for others though :thumbsup:
ps just noticed you got the spelling right too :clap:
