been reading up on this airpump fault and apparently it throws up a cel on the dash and puts the car into safe mode , so you would know if it was the airpump , also heard that there is 2 blanking plates available to do away with the secondary pump thus allowing the car to function normally , the ecu needs to be reset also to relearn that the the secondary airpump is not there , will put the link up later ,
