wheel geometry set up Munster
goosie208
hey lads
so i wonder if anyone can help me, anyone in the munster area, im based in Ennis, work in Limerick and go to Galway alot so any of those places are ideal
had my car tracked twice now in the same amount of days and its still not right
car pulls to the left and the steering wheel isnt straight because i have to steer into the road to go straight ahead
i was wondering if there is anywhere in my local area that are GOOD at doing 4 wheel alignment, preferably not just the tracking but camber and caster as well
somewhere that actually know what they are doing, i dont mind paying good money for it as long as they actually sort the effing car out :shock2:
thanks in advance
Tyres normally cause a pull goosie, ie uneven tyre wear, if inside of front right is worn off and outside is good then it will pull left.
What way are your tyres wearing?
I do 4 wheel alignment, camber caster but I'm in portlaoise...
good shout Midland!
my tires are quite old and very budget, ill take a look as soon as possible at my tires
cant say its something i thought to check :ponder2:
as david says tyre condition can effect it a lot try swaping left wheels to right and drive it see if it helps
go to tyre stop beside the NCT centre. kevin in there is a genius. he does ALL my cars including the bf's leggy and my foz. never go anywhere else! he comes from the rally sport and knows his cars very well. lovely guy, soundest chap you'll ever meet. tell him eileen sent ya
Been there a few times but he could never do it right as the car was too low for his equipment,
Used the other tire stop on the tulla road this time
Not sure if I want to use somewhere that uses the hanging type gauges as oppose to the more common rim mounted gauges
^^^ ah right thats weird. he tracked my s-bodies and they were proper low! both on fully adjustable coilovers, one polybushed. they were always spot on and i wouldn't go to anyone else than kevin...
The apparatus didn't fit
All the wheels were way inside the arches so he couldn't hang them over the tires
Needed wood to get it on the ramp lol he tried the old fashioned way with a ruler and stuff but gave up
