Wide track
basically it means this- "15mm wider rear track and wider rims (up from 7.5 to 8.0in) with wider- spaced mounting bolts. This increase in what is technically known as Pitch Circle Diameter from 100 to 114.3mm comes as a result of fitting larger, stronger roller bearings for better wheel control. Also, 114.3mm is a more commonly used PCD that allows a wider choice of wheel for those rallying the WRX in Group N."
help me out 06 sti, p1 rotas 18s 7.5 and 8.0can i run them on 225x 45 will it matter which are on on front and which are on back.
@ kerry sti im no expert but im nearly sure its recommended to run 225/40/18 rubber on the 8 inch rim both front and rear for wide track blobs anyway, im sure someone more qualified than me will come along to confirm or clarify
Are you planning on running 2x7.5" and 2x8" rims
I thought all permanent 4wd cars needed to have matching size/weight wheels front and rear or else you run into issues with transmission wind-up? I know when I tried it on our old Shogun that the trans overheated due to the difference - though thankfully that was selectable so I was able to complete my journey in 2wd with no further problems.
