Lex Luthor
Caff, did they take a measurement using some sort of light meter? your tints were not that far off passingCAFF said:mine just failed on front tints. mine is 40% and the maximum is 35% or factory tint is passable!! so have to peel off to pass an get it re tinted... rage
As long as your tints allow 65% or greater light through, it should pass. From what I'm reading/hearing, factory tints are about high 80's, so in essence you could get a very light tint put on, adding that to the factory tint as long as its above 65%, then it should pass.
They cant just say factory tints only if they are basing their failure on a specific reading
If my car went in and was borderline failure, I would ask them to prove the meter is checked by placing the 2 sensors together to get a reading of 100%. Only then will you know they are reading your window using a true zero
