window tinting?????
colmbarr1988
well lads im lookin for a place to get a tinted visor on me car
can anybody recommend a place in dublin pref northside?????
past their place a while ago and the sign was gone, it looked abandoned :dontknow: Maybe they moved or something
not northside but sure isint everything only 10 minutes from the m50
Place just off walkinstown roundabout vision.ie i think it is.Scouserlad got his done there and havent heard any bad reports about them.
Most motor factors that do reg plates should be able to do for you
:smokin:
:smokin:
window tintin
colmbarr1988 said:
der in ballycoolin phil
If its the same place they used to be in then they not there anymore
Is it just a visor your looking for or full window tints????
Any place that does the coloured reg plates should be able to do you up a visor.
Basically they use white reg plates with coloured numbers/decals and then sealed with clear film.( i think)
Getting a few bits on Friday will check for you if you can hang on till then
:smokin:
Revolution are only an hour down the road from you give them a call and im sure he can advise
