Thanks again and I gather the burgers were a winner.Your very welcome! Was great meeting you and your family! Put up pics when you have them fitted! They'll look fabulous on your wagon
Awesome. I'll look up instructions and allow a few hours to get it right [emoji106]I have only the lower one and from memory you need to measure and drill 2/3 small holes in your bumper about 4/5mm
That would be brilliant. Much appreciated John. Looking forward to seeing how it ends up next[emoji3]I have instructions at home, I'll take a pic and post for you. You basically put masking tape on the bumper for sliding the bottom one on until it clicks in place. The tape is to protect the paint and you just push it gently and evenly.
The top one, just open the bonnet and pop the grill off by releasing the clips with a long flat head screw driver, remove the factory mesh and then same thing with the masking tape to protect the paint as you push it in place until it clicks.
Any luck finding the instructions John? I tried to put the lower one in place but it's not sitting right and the middle bit is bending forward if that makes sense
Yes please if you don't mind when you get a chance. Thanks [emoji106]Yep I have them here, but I have the full bottom grill, not the half. The instructions for Top will be the same if you need those?
#hmblwgn
www.instagram.com/hhphoto7
