22B - Ballina Co. Tipp
welding it is the easy job jamie .getting all the bracing right and the feet the right length to support the cars weight is the hard part . turn the welder up loads and when you start blowing holes in the steel turn it down a notch or two and weld away :thumbsup:.
from experience if your looking to take underseal off or repainting the underside you wont do it properly from under neath the car. i tried it with the grale from under neath and ended up turning it over on its side after removing the doors and putting down an old matress and tyres :thumbsup: :thumbsup: :thumbsup:
