Wow.Hi
Just had a wee read of most of the post
Firstly is your current engine dead does it require a rebuild of is it OK and you just want more power
If its OK which I'm presuming it is as the post doesn't say otherwise I wouldn't be looking into a rebuild till its really needed
The engine in the car is generally well able to give more if in good nick
Decat and decent exhaust and intake the right size injectors and pump a decent turbo and intercooler and a good mapper will generally release the best from your current engine 300 to 330ish is a number that most std engines can do without being opened someone will push further and alot depends on driving style and usage
Next item is the gearbox I for one have no idea what the autos can handle power wise but unless you want to go manual with associated costs look into this bit first 6 speed is the way to go if funds allow
I spent around 11k get my ra to 400ish on a 2.1 forged and all associated upgrades and to be honest I wouldn't do it again even if the engine was blown I'd build std and map it up to a safe level
That's my opinion if rebuild is required then go for all you can afford if that's the route you want to go just remember much more power requires better gearbox suspension brakes become a pressing issue literally
Bigger brakes often require bigger wheels and better quality tyres are a must
Engine building is the tip of the iceberg
I bought a mates 93 ra totally mechanically std bar an exhaust and intake possibly not the best comparison as the early wrx ra had really short gearing and with 240hp was an absolute blast to drive way more fun than the 00 wrx ra with 11k engine build and 400hpWow.
First of all- thank you for your post. There's a lot of sense in what you said. And your honesty in relation to your own experience with building your Ra is , well, refreshing.
No.1. no, my engine is working fine .
It's the 2nd engine I had built 41000 km ago.
Unfortunately the original detonated ( finally traced it to a crack in one of the vacuum lines,at least I think that was what caused it along with a tired fuel pump)
I did an oil change recently and did notice couple of oil leaks developing... Along with possible steering rack leaking. Hard to tell exactly where it's coming from. I think I'm getting a bit of blowback pressure from the pcv setup. Again I'm not a mechanic and it seems almost impossible to find a competent mechanic to look at it for me. And just so we're in no doubt it drives me absolutely fucking mad. My car is in mint condition and I border on obsessive compulsive disorder about the condition it's in.( I find that most of us on here are exactly the same)
I've wanted to gain more power for a while now and always had the 350 ISH mark in my mind.
My car is my only one and my daily.
I don't put huge miles on it and this engine is coming up on three years old(40000 km-not a whole lot for three years)
My idea is to buy and build as and when the funds are there.
I'm not a race track merchant but am totally addicted to boost. I don't need to tell anyone here why . I just like creaming other yokes at lights etc.
I have been worried about the motor since I first noticed the leaks. I was off the road for the best part of 5 months the last time and it was a cluster fu*k. So I would like to have a longblock there just in case.
The 5eat in these are obviously not the best gearbox and I'm unsure of power handling capacity of it. I need to do more research on this. I have a floating memory of it being said the can handle 350 ish- but don't hold me to this- I could be wrong.
Suspension has been changed to bilstein hd at the front and uprated springs all around. Brembos all round 4pots front and 2pots rear - redone seals about a year ago. So cushdie on that front.
Bridgestone Potenza sports front.
Federal Evo on rear.
11 k sounds about right for your engine.
Why would you not go that route again??
380WHP is near 480BHPOk, so I've been toying with this idea for a while.
1st disclaimer- I am not a mechanic - I am a panel beater so have some very very basic idea of these engines and have some very minor experience in removing and replacing some components, i.e. intercooler, alternator,turbo, exhaust that type of thing.
So dumb down answers..
So, car is 2006 legacy wr ltd with EJ20x engine duel avcs, and 5eat box.
I'm looking for strong reliable 350-380 hp at the wheels.
I like the characteristics of my engine, very quick on boost and pulls nice.
Just want mooorr powa.
So where do I start? What's the best route to go?
Get a used engine? Get a short block( I've included the options from ICP)and start from there?
Are any of these a good option?
I don't want to get into changing wiring loom ect. Would like to keep tmic, standard turbo placement etc.
Or am I just mad?
I am aware of the cost involved....380WHP is near 480BHP
Are you willing to throw €10k+ at this?
Thanks for that Baz.I’m at the same conclusion as Kev (nivek) and modifying the same gf8 Sti wagon since 2009 , power levels rose from 280hp to 448hp which it’s at now , with 2-3 broken 5 speeds in the early part of the project at 350hp level and eventually going full 6 speed in 2013 and adding Brembos all round, couple of 2.5 forged engine builds , one I did myself in 2010 and then the second one after 80,000km , with stuff done to keep it together at 400-500hp and if I’m honest ,
If I was to pull everything apart again I’d use a good standard engine with a standard Sti quick spooling turbo and map to 320-320hp
I do a lot of track days and the difference on the stop watch between 350hp and 450hp is 1 second a lap as your on the brakes more trying to stop the thing
The best setup is to copy the factory, twin scroll Sti with a 6 speed gearbox, good brakes and decent suspension for covering ground on any road
Definitely not taken in a bad way at all Eoin.To be fair, I don't mean this is a bad way, but, obviously hunting the power, means hunting the fun factor.
I genuinely would believe a manual 6 speed STI swap would be the way forward, I've had an auto legacy B4, and when I eventually got a WRX, the comparison is unreal, much more fun, and the WRX was actually slower on paper
Just my 2c man
I appreciate that Ken. And I definitely like the idea of not having to change tranny( although "tranny" and "change" in the same sentence could mean something completely different )My advice would be to go with a new sti short motor and build it to 350-380BHP and leave it at that… talking about manual trans swaps etc etc is just madness imo.
You are wanting to maintain this as an everyday reliable car, you will need to be careful
I get you man, I meant change only the gearbox, even tho that's a lot of ball ache in itself, but my thinking was, its not a slow car, manual box would change the experience altogether..My advice would be to go with a new sti short motor and build it to 350-380BHP and leave it at that… talking about manual trans swaps etc etc is just madness imo.
fu*k it ,
Strip it out , cage it , full 6 speed conversion, nice engine build and drive on
Ya see- different ideas are starting to rise up.I get you man, I meant change only the gearbox, even tho that's a lot of ball ache in itself, but my thinking was, its not a slow car, manual box would change the experience altogether..
I've never done anything like that tho, so my opinions are kinda irrelevant....but I do still like to share em
