Altezza-Dan
Car is boosting at 1.2 bar max lately, It was mapped to boost at about 1.5 BAR peak. I'm also getting a bit of detonation aswell at about 5k rpm under full load, which is more worrying than the loss of boost. Power levels are also down from 270 to 240hp@fly The only change i made since the tune was a cat back exhaust system.
Is there any mechanical issues that could cause this or what i can check for? Simon said i should drive off boost until i can get tweak map to sort det out or use some NF.
