sean typer
Car failed nct today because since last may i was told,if it leaves the factory with a drivers airbag it should have one on for the test.Would have got an oe steering wheel if
i knew that.Question....where is the airbag light as i had an oe wheel on it when i got the car and never saw it?
Also is the light supposed to come on with the others and go out when the car starts?
On a side note.fitted cat pipe straight tru center and kakimoto back box for test,flew tru emmisions but got a reading of 106db....
I told him it couldnt be right.I even said my blitz at home would hardly be 106,to which he said"all our machines are callibrated"
Wtf i see the other lad stick the meter about 2" away from the backbox.
Should they measure it the same as the guards,meter away 45degree angle etc?
Also for the record the exhaust is quiet backbox is jasma stamped with 96db.
im fuckin raging
im fuckin raging
to nct man.(all they need to see is that light works)
For people that are supposed to me mechanics theyre clueless,saw them stalling a 911 countless times before and today the failed a guy on rusty brake pipes and told him to go get them cut out and welded!!!
fit a left rear wheelbearing before next sundays meet
